Dead Sony KV-27S15   Goto page Previous  1, 2
Clodbuster
PostPosted: Sat Nov 15, 2008 7:45 pm    Post subject: Reply with quote
Ok, this afternoon I removed the three transistors and resoldered the transformer. One of the pins on the transformer (the side with four pins) has never been soldered. (See Below)What do you make of that? I’m guessing leave it as is.
Also, will I need to get some heatsink compound for when I put the transistors back on or will I be fine with what was left behind from the old ones?
And I’m still not sure which resistor is the one I need to replace, maybe I’ll figure it out when I get the parts. I read something about R607 being the resistor that we’re talking about. Is the resistor pointed out in the picture below the one I’m looking for.
Thanks
Clodbuster
PostPosted: Wed Nov 19, 2008 9:08 am    Post subject: Reply with quote
Just wanted to take a minute to thank kuhurdler for all the help thus far and to keep the thread updated.
I have ordered the parts and just waiting on their arrival. I order them from electronix.com and at this point would recommend them to anyone. They were the most knowledgeable, helpful and friendly place I had looked at and called. There was a $10.00 minimum so I did have to order something else to meet that minimum but that’s not a bad thing.
Also, I would still appreciate any helpful comments, hints or information anyone would like to share.
PostPosted: Wed Nov 19, 2008 9:33 am    Post subject: Reply with quote
Yes, you'll want to use some new heatsink compound.
I'm sorry I haven't answered your resistor question. I just can't seem to recall if that is the correct one. It seems likely I guess.
Clodbuster
PostPosted: Wed Nov 19, 2008 10:42 am    Post subject: Reply with quote
No problem. Yeah I think it’s the one, the other resistors close to those two transistors don’t have the right values according to the resistor color codes, if I have those right.
Is heatsink grease the same basically as the compound or do I need specifically the compound? I think I can get the grease locally at Radio Shack.
PostPosted: Wed Nov 19, 2008 10:43 am    Post subject: Reply with quote
yeah same stuff. just be sure to clean off the old stuff first.
Clodbuster
PostPosted: Mon Nov 24, 2008 5:28 pm    Post subject: Reply with quote
Hello All,
I had a chance this weekend to put all the new parts in and everything went well. However, today I hooked the TV back up for the first time and it powered up but, I have audio only, no picture.
Any suggestions??? I did pull the back off to see if there were any obvious connections lose but found nothing.
Thanks for any help.....
Clodbuster
PostPosted: Mon Nov 24, 2008 7:32 pm    Post subject: Reply with quote
Before taking the TV back out I tried one more time just to see what it would do. Now it has a picture but it’s black and white. ???????
Clodbuster
PostPosted: Mon Dec 01, 2008 2:43 pm    Post subject: Reply with quote
Hope everyone had a good Holiday weekend......
Anyone have guess or answer to my problem?
Thanks!
PostPosted: Mon Dec 01, 2008 4:02 pm    Post subject: Reply with quote
Have had problems with C306 and C311 on the M pcb (one of the daughter boards. The Letter M will be printed on the board.) Also have had problems with IC301.
However, I would check all small connectors for being partially pulled out, check the M board for being fully plugged in.
Also, The transformer indicated on the pictured is not the driver transformer being talked about. What you want is T502 Horizontal Driver Transformer. It is a small transformer fairly close to the horizontal output transistor. If this transformer has bad connections it will cause a premature failure of all that you have replaced.
hope this helps
