ACME Enterprises   Riddled TV Repair Forum
Laptops For Less
FAQ
Login and Registration Issues
Why can't I log in?
Why do I need to register at all?
Why do I get logged off automatically?
How do I prevent my username from appearing in the online user listings?
I've lost my password!
I registered but cannot log in!
I registered in the past but cannot log in anymore!
User Preferences and settings
How do I change my settings?
The times are not correct!
I changed the timezone and the time is still wrong!
Posting Issues
How do I post a topic in a forum?
How do I edit or delete a post?
Formatting and Topic Types
What is BBCode?
Can I use HTML?
What are Smileys?
Can I post Images?
What are Sticky topics?
What are Locked topics?
User Levels and Groups
What are Administrators?
What are Moderators?
Why can't I log in?
Have you registered? You must register in order to log in. Have you been banned from the board? (A message will be displayed if you have.) If you have registered and are not banned and you still cannot log in then check and double-check your username and password. Usually this is the problem; if not, contact the board administrator -- they may have incorrect configuration settings for the board.
Back to top
Registration will give you access to features not available to guest users such as posting, and notifications of updates to your posts, etc. It only takes a few minutes to register.
Back to top
If you do not check the Log me in automatically box when you log in, the board will only keep you logged in for a preset time. This prevents misuse of your account by anyone else. To stay logged in, check the box during login. This is not recommended if you access the board from a shared computer, e.g. library, internet cafe, university cluster, etc.
Back to top
In your profile you will find an option Hide your online status; if you switch this on you'll only appear to board administrators or to yourself. You will be counted as a hidden user.
Back to top
Don't panic! While your password cannot be retrieved it can be reset. To do this go to the login page and click I've forgotten my password. Follow the instructions and you should be back online in no time.
Back to top
First check that you are entering the correct username and password. Maybe your account needs activating. This board requires that all new registrations be activated by clicking the link, sent to the email address you provided at registration. You were sent an email then follow the instructions; if you did not receive the email then check that your email address is valid.
Back to top
The most likely reasons for this are: you entered an incorrect username or password (check the email you were sent when you first registered) or the administrator has deleted your account for some reason. If it is the latter case then perhaps you did not post anything? It is usual for boards to periodically remove users who have not posted anything so as to reduce the size of the database. Try registering again and get involved in discussions.
Back to top
All your settings (if you are registered) are stored in the database. To alter them click the Profile link (generally shown at the top of pages but this may not be the case). This will allow you to change all your settings.
Back to top
The times are almost certainly correct; however, what you may be seeing are times displayed in a timezone different from the one you are in. If this is the case, you should change your profile setting for the timezone to match your particular area, e.g. London, Paris, New York, Sydney, etc. Please note that changing the timezone, like most settings, can only be done by registered users. So if you are not registered, this is a good time to do so!
Back to top
If you are sure you have set the timezone correctly and the time is still different, the most likely answer is daylight savings time (or summer time as it is known in the UK and other places). The board is not designed to handle the changeovers between standard and daylight time so during summer months the time may be an hour different from the real local time.
Back to top
Posting Issues
Easy -- click the relevant button on either the forum or topic screens. You will need to register before you can post a message. The facilities available to you are listed at the bottom of the forum and topic screens (the You can post new topics, You can vote in polls, etc. list)
Back to top
Unless you are the board admin or forum moderator you can only edit or delete your own posts. You can edit a post (for only a limited time after it was made) by clicking the edit button for the relevant post. If someone has already replied to the post, you will find a small piece of text output below the post when you return to the topic that lists the number of times you edited it. This will only appear if no one has replied. Please note that normal users cannot delete a post once someone has replied.
Back to top
What is BBCode?
BBCode is a special implementation of HTML. Whether you can use BBCode is determined by the administrator. You can also disable it on a per post basis from the posting form. BBCode itself is similar in style to HTML: tags are enclosed in square braces [ and ] rather than < and > and it offers greater control over what and how something is displayed. For more information on BBCode see the guide which can be accessed from the posting page.
Back to top
Can I use HTML?
That depends on whether the administrator allows you to; they have complete control over it. If you are allowed to use it, you will probably find only certain tags work. This is a safety feature to prevent people from abusing the board by using tags which may destroy the layout or cause other problems. If HTML is enabled you can disable it on a per post basis from the posting form.
Back to top
What are Smileys?
Smileys, or Emoticons, are small graphical images which can be used to express some feeling using a short code, e.g. :) means happy, :( means sad. The full list of emoticons can be seen via the posting form. Try not to overuse smileys, though, as they can quickly render a post unreadable and a moderator may decide to edit them out or remove the post altogether.
Back to top
Can I post Images?
Images can indeed be shown in your posts. However, there is no facility at present for uploading images directly to this board. Therefore you must link to an image stored on a publicly accessible web server, e.g. http://www.some-unknown-place.net/my-picture.gif. You cannot link to pictures stored on your own PC (unless it is a publicly accessible server) nor to images stored behind authentication mechanisms such as Hotmail or Yahoo mailboxes, password-protected sites, etc. To display the image use either the BBCode [img] tag or appropriate HTML (if allowed).
Back to top
Sticky topics appear below any announcements in viewforum and only on the first page. They are often quite important so you should read them where possible. As with announcements the board administrator determines what permissions are required to post sticky topics in each forum.
Back to top
Locked topics are set this way by either the forum moderator or board administrator. You cannot reply to locked topics and any poll contained inside is automatically ended. Topics may be locked for many reasons.
Back to top
Administrators are people assigned the highest level of control over the entire board. These people can control all facets of board operation which include setting permissions, banning users, creating usergroups or moderators, etc. They also have full moderator capabilities in all the forums.
Back to top
Moderators are individuals (or groups of individuals) whose job it is to look after the running of the forums from day to day. They have the power to edit or delete posts and lock, unlock, move, delete and split topics in the forum they moderate. Generally moderators are there to prevent people going off-topic or posting abusive or offensive material.
Back to top
Jump to:
Copyright © 2010 RiddledTV.com
