GE 31GT740 - High pitch squeel
Darryl
PostPosted: Tue Oct 02, 2007 10:55 am    Post subject: GE 31GT740 - High pitch squeel Reply with quote
This set just came in and I dont have the manual. It makes the high pitch squeel as soon as you plug it in. That leads me to think something in the secondary of the power supply tranformer is loading it down. Any service info online or any tips?
Appreciate any info on this one.
John
PostPosted: Tue Oct 02, 2007 10:55 am    Post subject: Reply with quote
Dave, sounds like the Horz. output transistor is shorted account of a bad
Flyback.
Eric
Daryl check the hot it maybe shorted then post again..Eric
Darryl
PostPosted: Tue Oct 02, 2007 10:56 am    Post subject: Reply with quote
Eric and John Thanks!!
Yes the HOT was shorted...Replaced and now no squeel. But when turned on, Hi
voltage comes up momentarily then goes in protection shutdown and
re-attemps to turn on. Repeating the same cycle three more times on its own.
Is the flyback a gonner? Or is some other part the problem? CTC203CA12 is
the chassis. Eric, I see you were going to post the service manual. It would
be helpful to have. Well thanks... any other info
would be a major help.
John
Darryl,Yes the flybacks gone, and if not careful will take out the New HOT
that you just put in.
Terry
Dave resolder the pins of the SMPS xfmr. also check and resolder the leads
to the small coil to the horiz. drive xfmr.
