Help With My 46" RCA Projection TV
DatorGator
PostPosted: Mon Jul 23, 2007 6:28 am    Post subject: Help With My 46" RCA Projection TV Reply with quote
I have 46" projection RCA T.V. it was made in 2001 about a month ago there was blue and red spot about the size of a basketball came up in the middle of the screen and want go away.Does anyone have any ideal what could have caused this and can it be fixed is there a easy fix for this problem. Thanks
PostPosted: Mon Jul 23, 2007 10:33 am    Post subject: CRT coolant Reply with quote
My first thought would be the CRT coolant getting cloudy. You can take off the back cover and look down into them to see if they look cloudy.
Use the green one as a reference if it is acting normally.
DatorGator
PostPosted: Mon Jul 23, 2007 11:16 am    Post subject: Reply with quote
should I do this with the TV turn off are with it turned on
PostPosted: Mon Jul 23, 2007 3:04 pm    Post subject: Reply with quote
either one, I would look first with it off. If I didnt see anything, I would check with it on.
DatorGator
PostPosted: Mon Jul 23, 2007 4:01 pm    Post subject: Reply with quote
now if I do see one that is cloudy does that mean that is is bad and are they easy to change and also where do you buy these do they charge up and will shock you
PostPosted: Tue Jul 24, 2007 6:07 am    Post subject: Reply with quote
I'd suggest we check them before we worry about how to replace them.
