Hitachi Model# 43FWX20B Projo tv how to remove leads from Fl
EricM
PostPosted: Mon Sep 24, 2007 10:39 am    Post subject: Hitachi Model# 43FWX20B Projo tv how to remove leads from Fl Reply with quote
Hi how do I get the leads out of the flyback there are 3 wires I need
to take out..The book says to push down and
twist the leads and pull..This is the first time I tried this..I dont
know how hard they should be to get out..I have to change the
converegence ic,s and I need to get the panel out to work on it..Thanks
for any info..Eric
Ming
PostPosted: Mon Sep 24, 2007 10:39 am    Post subject: Reply with quote
HI, It should push down that make the wire goes more
into the hole and then twist it out. The first time I
do this did not success. Sometimes need to isolate the
flyback or tripler so that it can have more room for
you to twist and push into the hole. Tripler is much
easier than flyback.
Terrry
PostPosted: Mon Sep 24, 2007 10:40 am    Post subject: Reply with quote
Eric, push down and twist try both ways and the wires should release quite
easily.
AlM
Should just pop out if you turn the wire just right. Don't yank on them or
you'll bust the little nubs that hold it in.
Al
EricM
Thanks Al I got them out now I know how to do it..I didnt twist enough..Eric
