  Advertise Here
HL-R5067W DLP color problem
TonyH
PostPosted: Sat Jul 05, 2008 6:31 am    Post subject: HL-R5067W DLP color problem Reply with quote
HL-R5067W DLP Customer replaced color wheel because of broken glass
filter, and then the unit would not operate at all other than the blinking
lamp indicator. I found the color wheel flat wire plugged in backwards now
unit will operate but the color looks slightly gassy, Can a weak lamp cause
this problem? There is a white smoke film inside the back bubble of the lamp
element.
Your help would be appreciated.
Doug
PostPosted: Sat Jul 05, 2008 6:32 am    Post subject: Reply with quote
You probably need to remove the jumper on the DMD module. It is a two pin
plug with a jumper like on a hard drive on the front of the DMD. There is a
slot for this in the shield cover low mid center. The new wheel may not
match the old DMD.
TonyH
PostPosted: Sat Jul 05, 2008 6:33 am    Post subject: Reply with quote
Jumper plug has been removed probably from the last time one was put in 2
years ago. I tried to jump the plug back to factory and the picture is
worse. Any other ideas
TonyH
Anything dark or black has green in it
Doug
PostPosted: Sat Jul 05, 2008 6:34 am    Post subject: Reply with quote
The new C/W should have come with a label with the necessary settings for
color and index-was the label still there attached to the L/E? If the
customer did it himself and got into the service menu then you probably have
a mess.
