  Advertise Here
KV-EX34M87 SONY TV
ubai
PostPosted: Mon Oct 29, 2007 6:12 am    Post subject: KV-EX34M87 SONY TV Reply with quote
Has anobody a solution
blinks twice green,once red for about 100sec. then it operates normally, i have resoldered power section .
PostPosted: Tue Oct 30, 2007 5:07 am    Post subject: Reply with quote
chassis AG-3E
ubai
PostPosted: Tue Oct 30, 2007 3:44 pm    Post subject: Reply with quote
kv-ex34M87 (huge tv) served for 7 years without trouble.
the only no. i found on pwr etc board is: CMKI-81x
also after resoldering tv becomes live after a very short time compared to as it was before, it takes 1-2 min. after red led
green blinks twice, relay also clicks all times.
set parts are overall apparently cold. and i cant locate the fault exactly.
when alive again pic&sound are crystal clear.
thank you for your kind attention.
Ubai
PostPosted: Tue Oct 30, 2007 4:08 pm    Post subject: Reply with quote
sounds like a cold solder joint to me. you might try getting a bright light and touch up many of the solder joints. also try poking at the board with a wooden stick, like a chopstick.
ubai
PostPosted: Thu Nov 01, 2007 6:27 am    Post subject: Reply with quote
cant locate bad area exactly, what do you suggest?
since it cant be started instantly ,cant acces service menu mode
:roll: thank you
Jakarta
PostPosted: Fri May 23, 2008 3:57 am    Post subject: kv-ex34M87 Reply with quote
Hi Ubai,
I have a same problem with your TV.
I bought it on 2001.
Did you get any solution ?
Many Thank's
