  Advertise Here
LCD Westinghouse LTZ-32W6
Mark
PostPosted: Sat Jul 05, 2008 7:08 am    Post subject: LCD Westinghouse LTZ-32W6 Reply with quote
When it connected to cable all screen are green,but on another input like DVD or HDTV work fine.Any idia what could be a problem.And if any have service manual I would appreciate.Sincerely Mark.
Randy_s
PostPosted: Sat Jul 05, 2008 7:09 am    Post subject: Reply with quote
Can you double check that model number? I am only finding Westinghouse LCD TVs starting with LTV, not LTZ. If it is the LTV-32W6, you need the main board, part number is listed as 5600600039. Good luck on getting it though. The company I work for is authorized for westinghouse. I have ordered parts on 27 Westinghouse TVs. I have received the part for 1 of those. It was the board specified for that model, but it was completely different than the board that was in the unit. All were eventually exchanged, or returned to customer unrepaired if out of warranty. You will be very lucky if you are able to satisfy this customer.
Have a great day!
Dave
PostPosted: Sat Jul 05, 2008 7:10 am    Post subject: Reply with quote
Look for the version on the board. And include that when you order the part
number. I have had numerous part order mishaps with them due to later
versions of boards being used.
Mark
Hi Randy! It is LTV-32W6 but I'm going on 12 of June to this customer so I will double check.Board is very expensive I think it not worse to fix it.
