tmgsr
Joined: 23 Feb 2010 Posts: 2 Location: Cincinnati, Ohio
Posted: Tue Feb 23, 2010 7:28 pm Post subject: Magnavox Convergence Template |
| Does anyone have the grid dimensions for a Magnavox 46" rear projection tv? I can't find it anywhere? Thanks in advance! |
tmgsr
Posted: Fri Mar 12, 2010 12:52 pm Post subject: Line Spacing |
| I need the line spacing for the template mentioned above. Does anyone have it? |
Joined: 22 May 2008 Posts: 600 Location: The Last Frontier
Posted: Fri Mar 12, 2010 7:43 pm Post subject: |
Here Goes,
Draw a box that is 28" high x 37 3/8" wide.
Draw a box within the box that is 26 1/8" x 36 3/4".
Spacing equalateral. (5/16" on sides and 7/8" top and bottom.)
at this point, using the drawn boxes as a reference, find the exact center and draw a centercross that extends all the way to the edges. I am suggesting doing it this way to minimize error.
From the Center go left and right in this sequence spacing. 4", 4 1/2" 4" and there should be 1 3/4" inches left to edge of inner box.
Starting again at the center going up and down with horizontal lines 6 1/2", 6 1/2".
Good luck.
PS: You could not find it anywhere because it does not exist. I had to measure from the original template to acquire your needed information.
As you can tell, I must be older than sin to have this template to measure. |
Joined: 28 Dec 2006 Posts: 2571 Location: Overland Park, KS
Posted: Sat Mar 13, 2010 7:35 am Post subject: |
Jesse,
you never cease to amaze me how far you'll go to help people.
You're one of the reasons this forum is great. Thanks. |
