Mitsubishi WS 55511 V21
David
PostPosted: Tue Jul 10, 2007 10:54 am    Post subject: Mitsubishi WS 55511 V21 Reply with quote
Set plays fine for 10 - 20 mins. then will S/D with the LED flashing for the 70 sec. just as when it's first plugged in . Will turn rite back on once it stops flashing with same senerio . No error codes , delete X-ray and same thing , monitor B+ , it's OK , Standby constant as it S/D so that supply isn't shutting down as I thot mite be the case with it flashing as it does . Do have manual , could us some thots on it if anyone has any . Thanks ,
David
Steve
PostPosted: Tue Jul 10, 2007 10:54 am    Post subject: Reply with quote
David.. have ya looked around in the horz drive area? Bad solder?
You didn't mention if you'd tapped around or whacked it!
---Steve
David
PostPosted: Tue Jul 10, 2007 10:55 am    Post subject: Reply with quote
Yea Steve , I did beat on it a bit and flexed the board ,no change . It is
pretty consistant and uniform in when it shuts down . The thing that gets me
is the LED flashes emidiately once it S/D as when the A/C is first plugged
in . Maybe that's normal , but don't think so . Oh Yea ,, it does display "
POWER INTERUPTION " each time it S/D
Glenn
Sounds like a HD model with the DM board in it. I've changed the 4 1000uf
caps on the DM that were bulging that caused the set to shut down
intermittent and reset like your describing. If they get too bad the set
will just blink.
Glenn
Steve
Well, I'm not an expert on those things, but if is displays"power
interruption" then I would be lookin' around for possible bad solder in
the power supply. Could be main P/S or STBY P/S...
Wish I was of more help!
---Steve
Steve
PostPosted: Tue Jul 10, 2007 10:56 am    Post subject: Reply with quote
Actually replaced this board once, 6 hundred dollars later I am stripping the board out of the DM shielded housing to find four bulging 1000 uF electrolytic capacitors. I Would replace them first then worry if this doesn't resolve it! Board is a bitch to get to but you will appreciate saving the 300 after the dud credit applied!
Steve
David
BINGO!!!!!!!!! Have found about 10 lytics pregnant in DM board . Will
report after replacement .
David
David
PostPosted: Tue Jul 10, 2007 10:57 am    Post subject: Reply with quote
Way to go Steve . Been playing for 2 1/2 hrs. now , before only 5 - 10 min..
My lytics were all 330 / 10 v. ......8 in all and all pregnant . Thanks ,&
God Bless----
David
David
Thanks Glenn , It was as you said , only all of mine were 330 / 10 v. --8 in
all . Thanks and God Bless
David
