Only Two Wires To transfer Two differnt voltages
Post new topic   Reply to topic    Riddled TV Repair Forum Index -> Anything Goes
John1397
PostPosted: Mon Mar 03, 2014 7:34 am    Post subject: Only Two Wires To transfer Two differnt voltages Reply with quote
[/img]http://pee.7p.com/cgi-bin/i/images/12_volt_to_120_volt.jpg
I drew up a schematic that shows location A and B which are 400 feet apart. I would like to run 12 volts DC in one direction and 120 volt AC in the other direction. The switch when on will hold the two relays closed allowing AC to flow from location B to location A when the switch is turned off both relays will open and connect the normally open contacts in both relays allowing the 12 volts from the battery to flow from location A to Location B. Will this setup work as it looks to me that it will work?
John
Post new topic   Reply to topic    Riddled TV Repair Forum Index -> Anything Goes All times are GMT - 6 Hours
Contact Us       Privacy Policy       Copyright © 2015 RiddledTV.com       Advertise on RiddedTV.com
