Panasonic CT-27G32V - dead TV with click   Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Mon Aug 03, 2009 10:47 am    Post subject: Reply with quote
It's an NPN transistor
http://en.wikipedia.org/wiki/Bipolar_junction_transistor
Transistor isolated from circuitry (or removed) & Meter on "Diode Test:"
B to E = infinity with leads one way - a ~.4 reading leads the other way;
B to C = infinity with leads one way - a ~.4 reading leads the other way;
C to E = infinity with leads either way.
PostPosted: Wed Aug 05, 2009 8:22 am    Post subject: Reply with quote
With Q801 removed & testing in diode mode:
C to E measures infinite with leads one way, & 0.6 with leads reversed and same for B to C.
B to E measures 0.25 with either polarity.
In R mode:
C to E measures infinite, & 1.6 Megohm with leads reversed and same for B to C. B to E measures 487 ohm with either polarity.
Should Q801 be replaced and not IC803?
PostPosted: Wed Aug 05, 2009 12:28 pm    Post subject: Reply with quote
Q801 is BAD - period. I'd get and replace both. When new transistor arrives compare new to old. Smile
PostPosted: Tue Sep 15, 2009 5:46 pm    Post subject: Reply with quote
Replaced Q801, but still no power up Crying or Very sad with same clicking behavior as before. New Q801 measured infinite/0.68 from B to C and B to E and infinite/infinite from C to E (good measurements and different than the old, bad part).
PostPosted: Tue Sep 15, 2009 6:21 pm    Post subject: Reply with quote
What about IC803 Question
PostPosted: Wed Sep 16, 2009 6:33 pm    Post subject: Reply with quote
Have not replaced IC803. The DC voltages measure 8.7v on pins 1,2,4,& 5, and 327v on pin3 (essentially same as before changing Q801). Pulled the datasheet http://pdf1.alldatasheet.com/datasheet-pdf/view/38478/SANKEN/STR58041.html
which shows the equivalent internal circuit.
With IC803 removed in diode mode measures between pins
3 and 4: 0.5 and infinite w/leads reversed (should be a C-E junction)
2 and 1: 0.9 and infinite w/leads reversed (should be a C-E junction)
4 and 2: 0.01 and 0.01 (should be a C-E junction)
3 and 2: 0.5 and infinite (should be a C-B junction).
PostPosted: Thu Sep 17, 2009 10:30 am    Post subject: Reply with quote
A Collector to Emitter junction (with NO damper diode or any other internal resistors, etc.) on a DVM set on diode check should read INFINITE in both polarities - device OUT OF Circuit. Pin 2 to 4 alone is one junction B-E on transistor on the left (Unless you stiil have in circuit and something's in parallel? Wink
PostPosted: Thu Sep 17, 2009 6:17 pm    Post subject: Reply with quote
All these readings are with the IC completely removed from ckt. in DVM diode mode.
If pins 2 to 4 are a B-E junction, then the readings still look no good anyway, and also no good between 3 to 4 and 2 to 1 (if these are pure C-E junctions?). 2 to 5 measures 0.02 w/either polarity. Is this IC bad?
PostPosted: Fri Sep 18, 2009 6:06 am    Post subject: Reply with quote
Rolling Eyes
Page 4 of 9
