| Author |
williams0999
Posted: Fri Jun 06, 2008 4:55 pm Post subject: Panasonic CT-32Hx41e |
| My Panasonic will CT-32Hx41e won't turn on. Is there a fuse in this tv that I could check? |
Joined: 28 Dec 2006 Posts: 2580 Location: Overland Park, KS
Posted: Fri Jun 06, 2008 9:43 pm Post subject: |
| yes, there is a fuse. its right next to where the power cord is connected to the TV. |
williams0999
Posted: Sat Jun 07, 2008 5:23 am Post subject: Panasonic CT-32Hx41e |
| That is what I thought and I took the panel off, but gosh it must be hiding, because I cannot see anywhere that a fuse is or would be. Any clues? |
Posted: Sat Jun 07, 2008 6:25 am Post subject: |
| If you post a picture I can point it out for you. |
williams0999
Posted: Sat Jun 07, 2008 8:18 am Post subject: Panasonic CT-32Hx41e |
The only way I could figure out how to get you pictures is through Shutterfly. So if you will log on with username: chuckwilliams0999@gmail.com and the password: 1234, you will see the Panasonic TV album with the photos.
https://www.shutterfly.com/signin/
[/img] |
Posted: Sat Jun 07, 2008 1:48 pm Post subject: |
| yeah, that little hole isnt going to do it. You're going to have to take off the whole back of the case to get to anything. it will be easiest to set the TV on the floor and put a blanket in front of it, then tip the TV on its face. Unscrew the 10 screws or so that hold the back case on. |
williams0999
Posted: Sat Jun 07, 2008 7:37 pm Post subject: Panasonic CT-32Hx41e |
| Got it off, found the fuse, have power once again. Thank you so very much for giving me the confidence that I could do this. My husband does not believe it. You are the best, thank you again. |
