  Advertise Here
Panasonic Model CT32SL13g Chassis AP411
johnC_
PostPosted: Sun Jul 20, 2008 2:03 pm    Post subject: Panasonic Model CT32SL13g Chassis AP411 Reply with quote
Could someone send me the s/m on this model. It show to be in Members under CT32SL14 but not the same chassis. Owner said turned off after leaving house, came back home to turn set on and know dead won't come on. Will be bringing set in tomorrow.
Thanks
Terry_
PostPosted: Sun Jul 20, 2008 2:03 pm    Post subject: Reply with quote
John, I don't have the schem. but I think I had one awhile ago and I changed
the regulator and a few caps in the SMPS primary circuit. I believe the fuse
went also.
Steve_
PostPosted: Sun Jul 20, 2008 2:04 pm    Post subject: Reply with quote
Find the service manual here:
http://www.mediafire.com/?yjzxz9jzgnm
This is a Panasonic manual, not a pdf file. After you unzip it navigate down through the directory structure to the 'SVC' directory. Inside there find the file 36sl13g.html and double click. The manual will open up in your browser and you will probably have to click a few things to allow the content to display properly.
If you don't have winrar to unzip the file, find it here:
http://www.mediafire.com/?ehyslzxbj5g
Good luck.
Jim_
Hi,a common problem with this model is a blown fuse caused by a bad deguass
thermistor.Change both and all should be ok,Jim
Ming
PostPosted: Sun Jul 20, 2008 2:06 pm    Post subject: Reply with quote
It is true. I have few case as this. the first one I checked it at two hours to make sure no any other problem then replace the same rating fuse. it was failed again few weeks later. I check it again, but can not find out any parts get problem.
Next way. is to change another degauss resister that have higher ohm at 8----to 10 ohms. The degauss effect is not better than the old original resistor.
Steve_
I have been replacing the thermistor with RCA 207768 for some time with no problem. That 'special fuse' could cause you and your customer a lot of problems. Might as well do like the customers do and wrap tin foil around it.
Tito
PostPosted: Sun Jul 20, 2008 2:07 pm    Post subject: Reply with quote
On this case to finish the repair,install a slow blow fuse.-
