  Advertise Here
Panasonic PT53TW53G that shuts down right after power up
chad
PostPosted: Thu Jul 10, 2008 3:09 pm    Post subject: Panasonic PT53TW53G that shuts down right after power up Reply with quote
Hello , can anyone point me in the right direction .. I have a Panasonic PT53TW53G that shuts down right after power up and the led flashes every 7 to 8 seconds ... Looks to be Code 1 ? Ideas on what to look
for ... I have 125volts going to it ... Please any help would be great !
Thanks
Chad
PostPosted: Fri Jul 11, 2008 10:50 am    Post subject: Reply with quote
Possible failed components are:
D502 Diode
C509 Cap on collector of HOT
Q551 HOT
Flyback
hope this helps
chad
PostPosted: Fri Jul 11, 2008 2:02 pm    Post subject: panasonic d-board PT-53TW53G ( JESSE MACK ) Reply with quote
I found one R517 burnt in 2 .... I know there is another chip that caused it .. but unshure .. so Im going to start testing ....
Do you know how I would disconect the projection Wire ? The big red one
so I can get the board out to check ..??
Thanks
Chad
PostPosted: Fri Jul 11, 2008 7:00 pm    Post subject: Reply with quote
Best option is to disconnect from the splitter. Slide the boot up the wire, push in, twist 1/8~1/4 turn either direction and pull out.
Can be a little tricky.
