Panasonic TV CT-32HXC43G - Blown Fuse
Tommy
PostPosted: Mon Jul 23, 2007 10:46 am    Post subject: Panasonic TV CT-32HXC43G - Blown Fuse Reply with quote
This set came in with blown fuse. Replaced fuse and it has played for sometime now. Does anyone have any history on this set. I cannot find any reason for the blown fuse.
TIA
Gary
PostPosted: Mon Jul 23, 2007 10:46 am    Post subject: Reply with quote
As per Panasonic factory tech assist:
1. use a slo-blo type fuse
2. an off tolerance or defective degause thermistor can
also cause this problem
Gary
Replace D803 part# D4DDF1R50001 intermitten causes F801 part # XBA2A00101 to blow
Ed
PostPosted: Mon Jul 23, 2007 10:47 am    Post subject: Reply with quote
May just be a fuse that stressed.
Not a particular advice for Panasonic...but fused blowing at turn
on..might be wise to check the "degaussing" circuit for bad solder..or
the actual device.
Terry
Did you unplug the degauss coil to see if it still blows fuses? If so then
perhaps the thermister is bad. Just an added thot.
Tommy
PostPosted: Mon Jul 23, 2007 10:48 am    Post subject: Reply with quote
Thanks Terry:
The customer told me that they had a power surge and it wouldn't play after
that. I didn't know that before they picked it up.
