Panasonic TV Model CT-3266Ce chassis AP384
Terry
PostPosted: Mon Jul 30, 2007 10:57 am    Post subject: Panasonic TV Model CT-3266Ce chassis AP384 Reply with quote
Does anyone have a schematic for this Panasonic TV Model CT-3266Ce chassis AP384? No vertical deflection. I changed I/C and a few caps. Tube is at customers home TOO DAMN HEAVY to bring into shop. Thanks
Terry
Gary
PostPosted: Mon Jul 30, 2007 10:58 am    Post subject: Reply with quote
sorry don't have schematic
check power source res, should be R400 something
likely near fly, probably 2-10 ohm, 1/2 watt
Terry
PostPosted: Mon Jul 30, 2007 10:59 am    Post subject: Reply with quote
Thanks Gary, This set don't have a R4 series resistorfor the vertical. There
is so much black stuff over the board that it was hard to find which res.
fed the vert. I/C. So I put my probe on pin 8 of the I/C and went to the +
side of the diodes and came up with D561and R552, that 1 ohm res. was open.
It did not seem like burned, but when removed it. it had a hole in the
bottom toward the board. Another one bites the dust.
