TVRE
Posted: Wed Jun 04, 2008 8:42 pm Post subject: |
Hi
Yes I would like to go ahead with changing the coolant.
I would really appreciate your help.
I am very advanced when it comes to electronics ant TVs.
I have repaired several small CRT TVs, but only 1 projection which was an old Magnavox.
I hope to learn more and more over time.
I still have not received the coolant so can you help me in preparation?
Also the TV is not very old it is a mid 2000 TV.
At this time the CRT assembly has been bolted out but nothing has been disconnected.
Thank you |
Joined: 22 May 2008 Posts: 600 Location: The Last Frontier
Posted: Mon Jun 09, 2008 9:27 pm Post subject: |
| I have gotten busy again at the business, I will post the instructions as soon as I can. They are fairly long and if not followed, it will cause you much, much, work in the convergence area and a template will have to me made etc etc etc. |
Posted: Wed Jun 11, 2008 8:49 pm Post subject: |
TYRE,
I am working on the procedure and I could use a favor from you as I
do not have a unit in the shop at this time and the pictures provided by
the manufacturer are woefully inadequate. I am going to post the
procedure for all to see as this is a very common problem with this brand.
Now, here is what I need you to do.
You seem to have a good camera, could you use high (Bright) lighting and take pictures of:
1: Straight down on one CRT showing all screws.
2: Here's a hard one: Straight up on the underside of the crt showing
the CRT pcb, Velocity modulation coil, Yoke and grounding lugs.
3: A close-up view of the IHVT. (Flyback) This is the transformer that
has three large second anode (red) wires and one smaller White
wire.
4: A view of the Yoke Harness where it plugs in to the circuit board.
There are two sets of three. One large and one small. (deflection
and sub-deflection)
I will Capture these photos using a screen capture and edit them with anotations in the procedure.
I appreciate your patience and you will be rewarded with a great
looking picture.
Jesse |
Posted: Tue Jun 17, 2008 9:14 pm Post subject: |
Ironically, I have just repaired a set with the droplet condition you show. I thought you should know that the condition is caused by an ongoing leak in that CRT. Make sure you replace the seal or the leak will probably not go away.
I have taken a bunch of pictures for the procedure and will be posting soon. |
