RCA 20F420T - picture too bright with retrace lines
Post new topic   Reply to topic    Riddled TV Repair Forum Index -> I Need a TV Repair Estimate
zeke2010
PostPosted: Wed Aug 18, 2010 1:09 pm    Post subject: RCA 20F420T - picture too bright with retrace lines Reply with quote
Make and model: RCA 20F420T 20" CRT TV
Manufactured by: TTE Technology
Purchased: about 2 years ago for $108 Walmart $145 with tax and recycle fees
Appears to be a reconditioned unit as I now notice wear on areas where there should be little or none.
Worked fine for the last 2 years. FActory build date is June 2007
Trouble started when I turned it on one morning -- it worked fine for about 20 seconds and then turned itself off. I could not turn it back on. The red power light would go out for about one second and then come back on.
After doing a reset by unplugging it for more than 5 minutes, I tried again with the same results.
I then took the cover off and looked for overheated or poorly soldered components. Nothing real obvious although one resistor looks like it is running a bit hot as it has discolered the circuit board more than normal.
With the cover off, I was able to get a very bright picture with vertical retrace lines on it. The TV would turn itself off every 15 minutes or so. If I activated the menu, it would turn itself off almost immediately (2 or 3 seconds).
After many tries I was able to very quickly activate the menu, move to the picture menu and turn the brightness down from 50 to 00.
The TV nows stays on when I activate the menu but is still way to bright with vertical retrace lines. It also turns itself off after 30 minutes or so. Putting a fan near the circuit board to try to cool off any overheated components did not noticeably change anything.
Is this tube type TV worth fixing in a repair shop?
I cannot find any circuit diagrams on the net nor any manuals which I can download for free. I do have an electrical engineering background, so I am comfortable around electronic devices and I have but kit TVs together so soldering is not a problem...
Should I continue with trying to fix it or just buy a new LCD television?
Thanks for any advice you can give...
Zeke2010
PostPosted: Wed Aug 18, 2010 2:18 pm    Post subject: Reply with quote
something is overdriving your screen voltage. It could be a short in the neck of your CRT, but I assume it is one of the transistors that is driving the voltage level to the CRT. I know that is vague, but thats about as helpful as I can be.
If you can fix it yourself, it might be cost effective. If you have to take it to the shop, it will likely be cost prohibitive.
PostPosted: Wed Aug 18, 2010 3:55 pm    Post subject: Reply with quote
Should be same chassis:
http://elektrotanya.com/tcl_21e12_rca_14f512t_chassis_m123sp_sch.pdf/download.html
grace01
PostPosted: Wed Aug 18, 2010 11:18 pm    Post subject: general Reply with quote
hiii
i m new in this forum and i just need a help in it and i wish that this site
will response me we;lll,,,,,,,,
i m interested in it
_______________________
Earn an Extra $1000 to $1200 per month doing Part Time Data Entry Jobs! Work from home data entry jobs to post simple data submissions on Internet. Make $1 per entry. Easy form filling, data entry and ad posting jobs. No selling, No phone calls, No Marketing. No Investment. Bi-weekly payments. Full Training Provided. Pls visit: Data-Entry
PostPosted: Wed Aug 18, 2010 11:27 pm    Post subject: Reply with quote
Spam filter's not working.
PostPosted: Thu Aug 19, 2010 6:51 am    Post subject: Reply with quote
there I fixed the link for you.
I've never had to screen for job listings in the spam filter before. Must really be a rough economy.
PostPosted: Thu Aug 19, 2010 8:54 am    Post subject: Reply with quote
Maybe a "Jobs" subforum Question
Don't forget about the EEPROM. You can get some real interesting symptoms if its been corrupted.
Post new topic   Reply to topic    Riddled TV Repair Forum Index -> I Need a TV Repair Estimate All times are GMT - 6 Hours
