RCA 24V511T, DEAD
JoeJoe
PostPosted: Thu Sep 06, 2007 10:52 am    Post subject: RCA 24V511T, DEAD Reply with quote
Hi Folks,
I need help on repairing this RCA Model 24V511T, service no. 24V511T FX61,
chassis M134C. Set is dead. Replaced shorted D823. Main fuse did not blow.
If anyone has worked in this type of chassis, please email any helpful tech tip.
Thanks,
Joe
John
PostPosted: Thu Sep 06, 2007 10:52 am    Post subject: Reply with quote
Joe, check D826, (266891) 8.2 volt Zener 1/2W, R419 (680 ohm 1 watt) , Check
T802 Line choke may have an unsoldered lead.
If the relay clicks but no voltage at the Collector of the HOT check Check
Ic801 (str-W6735)
D810 (F104)
R813 (4.7 ohm 1/4 watt)
John
Eric
PostPosted: Thu Sep 06, 2007 10:53 am    Post subject: Reply with quote
Joe check this..Eric
*RCA : 27F522T M134C chassis : Dead*, Found burnt R826 (179284) D823
(270876) Q820 (268370) Q821 (20434) Zener D834 (268340) - replaceing all
fixed problem
