RCA 27V412T
stevo
PostPosted: Sun Jun 10, 2007 3:17 pm    Post subject: RCA 27V412T Reply with quote
HELLO I NEED HELP WITH MY RCA 27V412T,, ITS NOT TURNN ON ,, I CHECKED THE FUSE ITS FINE BUT WONT TURN ON ... PLEASE HELP TY ..
PostPosted: Sun Jun 10, 2007 8:05 pm    Post subject: Reply with quote
can you post the chassis number for us... something like CTCxxx - where xxx is a number
stevo
PostPosted: Mon Jun 11, 2007 4:23 pm    Post subject: rca 27v412t Reply with quote
chassis #M134C `for my rca 27v412T IT'S NOT TURN ON .. ..
CHASSIS #M134C.......
PostPosted: Mon Jun 11, 2007 4:50 pm    Post subject: Reply with quote
I'd check the H.O.T. first
here's a couple of other tips I found for that chassis on the internet:
RCA 27F520T DEAD R419, 680 OHM 1 WATT RESISTOR
RCA 27F520T Dead Found usoldered lead on T802 line choke
stevo
PostPosted: Tue Jun 12, 2007 5:35 pm    Post subject: rca 27v412T Reply with quote
ok ku thanks...but its that the same chassis what would i need to do to fix it myself .. im not to deep in repair but i have little knowledge on hands on ,, please more tips will help on how and whatto do to repair...thank you ...
PostPosted: Tue Jun 12, 2007 7:14 pm    Post subject: Reply with quote
Well, I would open it up and discharge the CRT.
Then I would find R419 (a resistor) on the circuit board and confirm that it measures 680 ohms with an ohm meter. if it does not, replace it with a 680 ohm resistor.
Then, I would find T802 (a transformer) on the circuit board and make sure all the metal solder points look solid. Or you could just take your soldering iron and reheat them all, just to be sure.
stevo
PostPosted: Sun Jul 01, 2007 6:20 am    Post subject: Reply with quote
thanks Ku ,, so imma give it a try cuz i didnthave time to but i'ce read ur post and i'kll do it .. when u said discharge CRT how ..u mean the power supply or ... anymore tips would help thanks again ....
PostPosted: Sun Jul 01, 2007 8:26 am    Post subject: Reply with quote
you can discharge the CRT by following this:
http://riddledtv.com/repair/journal/DischargeCRT/index.html
