Guest
Posted: Sat Jun 16, 2007 11:01 pm Post subject: |
Don, what happens when you turn down the screen control on the fly? I just
finished a CTC187CN3, a 32"er. It had a bad 100UF.250 V. cap in the SMPS
circuit gone bad queer display tho. Also some bad solder around the fly and
pin xfmr.
Terry |
Guest
Terry, adjusting the screen controle only darkens the picture, the lines remain. Do you have a location number on that 100mf/250v cap? I dont see any at that value in here.
Don |
Guest
Posted: Sat Jun 16, 2007 11:02 pm Post subject: |
on the 200v source to the R,G,B outputs.......
Peggs |
Guest
Terry, I stand corrected, I found that cap and I do not have that value (100mf/250v) in stock. I do have one at 100mf/200v. I guess this will have to wait.
Don |
Guest
It is located in front of the SMPS transf. It is C4107K on this chassis.
Terry |
Guest
No I'd not use a 200V. it will come back to haunt you. They don't overkill
when they build these things. I also had only a 200V. So I did find a 350V.
on thats a bit overkill but will be OK tho. Have a nice weekend all you
great techs.out there. |
Guest
Posted: Sat Jun 16, 2007 11:03 pm Post subject: |
Don follow from pin#6 of flyback to R4701 a 10 ohm resister to Cr4702
diode to C4703 a 47X250 volt cap
you should have 185 volts on that cap if low change it..Eric |
Hilton Guest
Don, I haven't read all the post on this problem yet,
but don't overlook the eprom. I've had several sets
with retrace lines , sort of looks like a weak crt
only ending up being the eprom. Be blessed, Hilton |
alexmotta
Posted: Fri Jan 30, 2009 5:26 am Post subject: GE 35GT695 with a CTC187CN3 chassis - manual needed |
| I am sorry to intrude in your topic, but I am about to retire a GE 35GT695 with a CTC187CN3 chassis because I don't have the circuit schematics. Would someone have it? Or would someone know where I can get it? Thanks! |
