Relay clicks, no power 46EX3B Hitachi 1993   Goto page Previous  1, 2
PostPosted: Wed Mar 04, 2009 3:31 pm    Post subject: Re: Relay clicks, no power 46EX3B Hitachi 1993 Reply with quote
troubleshootn wrote:
1993 hitachi 46ex3b projection
I hit the power button the relay clicks on supplys voltage all across the board, it checks at 120 volts at the first set of fuses drops to 65volts at sum type of resistor, then drops to 35 volts on pretty much the rest of the board. There is 35 volts on all the crt 's with power on, i checked the voltage at iso901 STR-M6511 its at 65 volts I was told this could be a possible problem, but I have no idea what test is needed to check the part or if this is even the problem???? Has anyone ran into this problem im sure it is simple, but my limited knowledge in the area is not helping.
Any help would be great.
Thanks Caleb
Does any part of this lead anyone to believe he had changed the regulator? Or did I interpret incorrectly or miss something?
