| Author |
rich
Posted: Tue Jul 31, 2007 1:29 pm Post subject: Sony KV-32FS120 dead, blinks 5 times |
| I have a Sony KV-32FS120. The set is dead and won't turn on. The power light flashes 5 times. Do you have a listing for the fault codes, or what area I should look at? The horiz output transistor is good. |
Joined: 28 Dec 2006 Posts: 2571 Location: Overland Park, KS
Posted: Tue Jul 31, 2007 2:25 pm Post subject: |
Chassis BA6 for anyone else's information:
I would check the Bridge rectifier first to see what voltage you are getting. I have a note here to check D611 which is the bridge rectifier.
Here are the Sony blink codes:
Unit is dead and there are no blinks---Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
NINE blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
TEN blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Intermittent problems ?? This is a great feature. You can also bring up these fault codes ON-SCREEN to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
So, now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking 4 times....This would tell you that you have no vertical and that is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault. |
Disclaimer:
Contact Us
Privacy Policy
Advertise on RiddedTV.com
