  Advertise Here
Sony Tv turns Red
Post new topic   Reply to topic    Riddled TV Repair Forum Index -> I Need a TV Repair Estimate
dann.garber
PostPosted: Mon Sep 13, 2010 2:10 pm    Post subject: Sony Tv turns Red Reply with quote
I have a Sony KP-51WS505 rear projection and when I turn my TV on it is fine for about 5 seconds then the whole screens fades into a red so there is nothing on the screen but red, and then the TV shuts off itself. Before this started happening only the red and green bulbs worked and there was no red color on the screen.
dann.garber
PostPosted: Tue Sep 14, 2010 10:33 pm    Post subject: Reply with quote
correction the blue and green bulbs were the only ones working and the red bulb was not.
PostPosted: Tue Sep 14, 2010 10:38 pm    Post subject: Reply with quote
What happens if you run the set without the CRT board plugged onto the red tube?
dann.garber
PostPosted: Fri Sep 24, 2010 11:35 am    Post subject: Reply with quote
I have no idea how to do that.
PostPosted: Fri Sep 24, 2010 9:09 pm    Post subject: Reply with quote
On the opposite end of the picture tubes from the lit screen end, there are printed circuit boards that plug onto the end of each CRT. Gently wiggle and pull board off of the RED CRT (do NOT let this board come into contact with any metal) and try running the set.
Post new topic   Reply to topic    Riddled TV Repair Forum Index -> I Need a TV Repair Estimate All times are GMT - 6 Hours
