Toshiba 23WL56G service menu code   Goto page Previous  1, 2
jcv06
PostPosted: Wed Sep 21, 2011 12:45 am    Post subject: 23WL56G ..... Reply with quote
Again, thanks for your answer. If I remember well, I told you I am French. So, could you at leas write word instead of CCW, LVDS ..... Sorry for the first picture but I had to turn it horizontally. These streaking lines are flashing.
Regards
Jean-Claude
PostPosted: Wed Sep 21, 2011 1:40 am    Post subject: Reply with quote
CCW = CounterClockwise
LVDS = Low-Voltage Differential Signaling
What about: "If so, streaks are on left of ALL objects? Or just objects on the right side of the screen?"
jcv06
PostPosted: Thu Sep 22, 2011 1:15 am    Post subject: Reply with quote
Hi, my friend,
Thank you for your message again.
Answering to your question, these streaks are on all objects, mainly bright (white) dots and lines.
You know, the main problem is to access adjustment menu (as the mute mute menu sequence does not work). Then, I should be sure it is not an adjustment problem or some hardware problem. Don't you think so?
As I said before, it was so easy when adjustments were done using potentiometers on board.
Again, thank you very much for your help.
Jean-Claude
