Toshiba 57H82 - No Picture
Post new topic   Reply to topic    Riddled TV Repair Forum Index -> I Need a TV Repair Estimate
d_fisher
PostPosted: Sat Dec 01, 2007 11:16 pm    Post subject: Toshiba 57H82 - No Picture Reply with quote
Make & Model Number: Toshiba 57H82
Chassis Number: TAC 0265
Current symptoms: Sound but no picture
Any symptoms that led up to the current symptom: For a few weeks before the screen would be completely white when first turned on. After 1-2 minutes the picture would suddenly return to normal.
The picture went out the night before the Ohio State/Michigan game. Had to purchase a new TV that night since missing the game was not an option! Trying to determine if its worth fixing and placing in my finished basement.
If it costs more than I want to spend, are there places that would buy the TV in the condition its in now? There is a little burn in on the left and right edges from watching non-HD signals. Even with that I had no plans to replace the TV. I was still pleased with the picture right up the point that I had the problem.
Thanks,
Doug
PostPosted: Sun Dec 02, 2007 9:25 am    Post subject: Reply with quote
I worked an a set identical to yours, except it was the next size down.
you can read up on that repair Here
While I was messing with it, one of the sypmtoms of the bad CRT board was a white screen. That would lead me to believe that yours is facing the same problem. Most likely a shop would just replace the Green CRT board instead of jumpering accross it like I did.
Parts <$100
Labor ~$2 - 300
delivery = unknown
of course that is just a rough estimate
d_fisher
PostPosted: Sun Dec 02, 2007 9:35 am    Post subject: Reply with quote
Thanks. I think $400 is a reasonable and now just have to call around to the local shops.
Post new topic   Reply to topic    Riddled TV Repair Forum Index -> I Need a TV Repair Estimate All times are GMT - 6 Hours
