Toshiba projection shuts off
Post new topic   Reply to topic    Riddled TV Repair Forum Index -> I Need a TV Repair Estimate
Time4wine
PostPosted: Fri Jul 25, 2008 7:57 am    Post subject: Toshiba projection shuts off Reply with quote
I am having an issue with our tv just wondering if its worth trying to fix or not. Tv is about 6-7 yrs old.
1. Make & Model Number: Toshiba 43HX71
2. Current symptoms: first turned on and shut off within 1-2 minutes now, turns on (only if you unplug it) with no picture just sound and turns off if you try a adjust anything or shuts off on its own within a few minutes and then the "on" light blinks
3. Any symptoms that led up to the current symptom: Awhile ago the picture would get funky but that went away. The day this happend a big thunder storm went thru maybe a power surge did this??
4. Location: Somers CT
Thanks
filly88
PostPosted: Mon Sep 13, 2010 7:49 am    Post subject: tv plays,fickers in brightness,goes from green to red,& Reply with quote
as I said in intro it does all that then it shuts off and red LED blinks but not in code but when menu button is push it gives a recorded mes. ( FAN OFF and then 2 codes....1st code E 11415...2nd code....L 11685.....
any ideas ,I would really like to know if I can fix this and how much $$$$ i am lookin at It is a Toshiba 50 HM66........
Post new topic   Reply to topic    Riddled TV Repair Forum Index -> I Need a TV Repair Estimate All times are GMT - 6 Hours
