White, Blue, Green & Red lines Sony KV-32FS100   Goto page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sun Feb 14, 2010 11:53 pm    Post subject: Reply with quote
On the left side of chassis (parallels tuner) there should be a "claw" that releases chassis. Complete removal of board is NOT necessary to remove and replace these caps.
From Service Manual:
WARNING: BEFORE REMOVING THE ANODE CAP
High voltage remains in the CRT even after the power is disconnected. To avoid electric shock, discharge CRT before attempting to remove the anode cap. Short between anode and CRT coated earth ground strap.
Patsfan34
PostPosted: Fri Feb 19, 2010 3:13 am    Post subject: Reply with quote
Ok. So as long as I don't try to remove the ANODE CAP. I should be fine replacing the capacitors with discharging? TV has been unplugged for 2 weeks. There may or may not be any charge. What would you do? Last question on this subject. lol
PostPosted: Fri Feb 19, 2010 6:49 am    Post subject: Reply with quote
Leave the anode connected. There should be enough room to maneuver chassis to work on.
Patsfan34
PostPosted: Fri Feb 19, 2010 2:57 pm    Post subject: Reply with quote
I love how you avoid answering me straight out. lol Do I need to discharge the CRT before I work on these particulars capacitors or not? lol
PostPosted: Fri Feb 19, 2010 3:03 pm    Post subject: Reply with quote
just do it. It's super simple and won't kill you.
Patsfan34
PostPosted: Sun Feb 21, 2010 5:58 pm    Post subject: Reply with quote
When you say just do it. Do you mean just replace the capacitors or do you mean just discharge the CRT first? lol I assume you mean to just replace the capacitors already. lol
PostPosted: Mon Feb 22, 2010 10:21 am    Post subject: Reply with quote
just discharge the CRT. It literally takes less than 5 seconds.
PostPosted: Mon Feb 22, 2010 1:32 pm    Post subject: Reply with quote
With the proper equipment, it will take approximately 1 minute per capacitor.
Total time: 2min. 30sec.
I'm allowing a 25 sec. coffee break between. Wink
Patsfan34
PostPosted: Mon Feb 22, 2010 11:13 pm    Post subject: Reply with quote
Ok. Well you tell me how to go about doing that without making one of those rigs to discharge it. I got a freakin screwdriver but not that other stuff.
PostPosted: Tue Feb 23, 2010 8:04 am    Post subject: Reply with quote
Well, this should be fun. I'll do my best to hold your hand by explaining why we're doing what we're doing. Hopefully that will be enough to arm you to improvise with whatever you've got.
The goal is to create a conductor from the anode of the CRT to the Aquadag. I know that sounds complicated, but that basically means from the charged area underneath that rubber grommet (anode) to the grounded metal springs on the outside (Aquadag).
In the how-to I wrote, I recommend the screwdriver because it has a fat insulated handle. In reality, you can use anything that is metal to create that conductor path between the Aquadag/anode. But along with creating a conductive path, you want to make absolute sure you don't touch that conductor while the CRT is being discharged. So make sure you INSULATE your hands and any other body part from anything conductive.
I've seen pros discharge CRTs by using two long handled screwdrivers. They criss-cross them and touch the Aquadag and anode while touching the metal of the two screwdrivers together. So two screwdrivers alone could create this conductor path. I would not recommend this method for a first timer.
I assume you have some kind of wires somewhere:
- Strip both ends of a wire
- wrap one bare wire end around the springs on the bell of the CRT
- wrap the other bare end around the metal of a screwdriver
- with one hand in your pocket, and the other hand touching ONLY the handle of the screwdriver...
- push the tip of the screwdriver underneath the metal grommet (anode)
- you should hear a ZAP and the CRT will discharge
- repeat as needed until the CRT no longer zaps.
Please post back with whatever portion was not clear enough.
Page 3 of 5
