Zenith SY2551S retrace lines   Goto page Previous  1, 2
Guest
PostPosted: Mon Jul 23, 2007 10:53 am    Post subject: Reply with quote
Ken, Make sure you change F mode from 0 to 1 and get to the factory
adjustments and go to 24 for the Red cut off , 25 for the Green cut off, and
26 for the Blue cut off.And make sure that 00 F mode returns Back to 0 after
you set it to 1 for adjustments. And the 06 AC on back to 0.
John
Ken
Guest
PostPosted: Mon Jul 23, 2007 10:54 am    Post subject: Reply with quote
Thanks John, that did the trick! Poor old CRT, the blue gun is almost done.
The TAC switch was the source of the Vol down problem. Now for some reason
the TV always powers up with the user menu displayed. Not sure what's
causing that. thanks for the advice!!
Ken
Greg
Guest
You still have the Service menu in Factory Mode 1, change back to 0. That
should fix it.
Greg
Dennis
Guest
PostPosted: Mon Jul 23, 2007 10:55 am    Post subject: Reply with quote
Try this --- Auto program set -- check that band setting is 5
Dennis
J
Guest
PostPosted: Mon Jul 23, 2007 10:56 am    Post subject: Reply with quote
Ken, Try Resetting the Clock and then Scan or Auto program the channels.
That may get rid of that
Problem.
John
Ken
Guest
Thanks, guys, it did just need an autoscan, then it was happy. Seems like
if you then re-enter serviceman mode after an autoscan, you have to rescan
channels again once you exit or the menu pop up returns.
Ken
